FX4BR
Just saw this thread. The second I got to the part with the photos/description, I went and checked mine and they are not broken, thank goodness. DESILVAFX35 you must have been pissed/stressed.
and always remember:
seal off and without limited warranty for not protecting firmly by oneself!!!"![]()
:tongue (2):and always remember:
I'll send it to you.
in my opinion I would guess that this design is strong enough for the majority of cars that they are used on.
I personally believe the big heavy wheels are a major contributing factor to this failure,
these 24's are huge 32" diameter and pretty damn heavy. what works with 45, 55 pound wheels oscillating and exerting forces against it may not be able to handle 85 95 pound plus wheels exerting those same forces, that's my guess.
obviously that's enough thread engagement to not have any failures with a large number of these out there,
of course theres still always the possibility that these threads were damaged on assembly or maybe even machined a few thousandth's off, even cnc can have errors, a slip in tolerance would make the thread weaker and more prone to a failure like this also.
in the end I would advise that when the intended fitment of these shocks are larger vehicles like SUV's with potentially big and heavy 22" and 24" wheels, there needs to be a bit more strength at this joint than just the 4 1/2 threads of engagement can provide., if thread engagement was increased to even 15mm it would more than double the strength of this joint and I think there's def room for at least 15mm end cap thread engagement if not more.
if they can do raw aluminum it will make the welding a lot easier but if that's a real headache then I can deal with the anodized finish too...
