From the manual, it says to use the drain plug, and replace the gasket. It looks like this is done with engine off, but after the fluid has been warmed. Then it says after replacing the plug, to drain from the small hose going to the rad. This is done with the engine running and the fluid is drained while it is being refilled at the top with new fluid. As I read the manual, when draining out of the plug, with the engine off, that the fluid is drained, then it is refilled, but it doesn't explicitly say the filling needs to happen while the fluid is being drained when draining out of the drain plug. It would also seem that if using the drain plug, one would let he fluid drain till it stops, then put back in the same amount of fluid. For draining out of the small hose, it does say to drain and fill at the same time and with the engine running. My guess is draining out of both locations removes more of the old fluid. Is my understanding of draining with the plug, one drains, then fills with engine off, but when draining from the hose, one drain and fills at the same time with th engine on.?
---------- Post Merged at 10:28 PM ---------- Previous Post was at 10:27 PM ----------
