- Boston, MA
Thanks for the correction EG. I was base on the fact how bicycle works. Same amount of work with smaller gear, you will need more revolution to get to the same distance. Sorry I am not a mechanical guy. :.smile:
You actually said it right. If the crank pulley is underdriven (smaller), it'll cause more revolutions on the alternator pulley (since they're connected with a belt). It generates more heat & wear on the alternator and the extra energy it generates are not used. It's just three separate cases and you explained the third one
Now that I'm thinking of it, technically speaking, just using the crank pulley may be a better solution for people using aftermarket audio systems?? Dee, maybe you won't need that second battery at all?? :hmmmm:
