thanks guys... to think I originally started all this cause I didn't want to spend the $1,900 it would have taken to match my front rotoras with rear rotoras
in the end that would have winded up cheaper & a whole lot easier for me, but, at least the good to come out of this is all my trials & fitment mods will help everyone else have these too, so it was worth it in the end
reposting this from a post I made to eg3's thread for those that watch this thread:
just spoke to justin, he says that he did tell you that the brakes themselves are a little cheaper than the front BUT also said that there def are add'l parts necissary too...
discussed a few things with him, hopefully he's going to sort out his end & these rears will be available soon, I told him about the bolt issues & about the banjo bolt length issues too, he also noticed that the aftermarket brake lines include shorter banjo bolts ,but he didn't fully realize weather it actually still bottomed or not on his install, he just tightened them & they don't leak, but if the bolt bottoms & deforms the end even a little it can impede fluid flow. the problem is the akebono's are not really designed for a banjo bolt at all, they are designed for & use a flared hard line on the oem install, luckily there is a flat boss & enough thread engagement with the correct banjo fitting for it to still work, but the bolt length is critical, too long & it'll bottom, too short & danger of stripping the threads on install or worse, falure in use... he's going to look into these few things, took my # direct & at this point he's going to be my go-to guy instead of joe from here on out... hopefully soon we'll be there... I'm really trying to get this put togeather...
