i just received my dakota digital stuff, now im just waiting for the fans, but i was wondering which fan out of the two is considered the "fan high"? would it be the one with more fins?
i also just finished going through the the instructions and its looking like there will be 3 wires that will be taking power directly from the positive battery terminal, i will be feeding the 3 wires to the fuse holder you recommended (from ebay with the 4gauge wire) but would the 40A fuse still be okay or should i get something a little but higher? (i just re read the instructions and it says the controller needs a 12v from the battery, so 4 wires total)
for the green wire on the relay it says "Connect to fused 12V battery circuit that can run cooling fan" i was thinking about connecting that to 12v key in ACC wire with a 10A fuse for each relay, or would the 12v key in RUN be better for this?
LAST Question, where is a good place to mount the controller? i was sitting in my truck yesterday and couldnt find a good spot
