FX lug pattern
The sidewall bulge is the next part after offset that determines if the wheel/tire will rub. 305 on a 10" is decent sidewall bulge, your 265 on a 9" should be less sidewall bulge and less wheel/tire to get near the wheel wells. Fronts, mazzzur pushed his clips up to gain a little extra clearance.
Can you explain how I push the clips up or where they are? I would assume I need the remove the wheel to do this? Thanks.
FX Bolt Pattern
5x114.3 or 5x4.5
FX Factory Studs
30mm
FX Lug Nut Specs
M12x1.25mm
FX Lug Nut TQ Specs
80 ft-lb
FX Centerbore
66.1
OEM Sport Wheel Specs
20x8
5x114.3
ET +40
OEM Sport Tire Specs
265/50-20 32psi is recommended
OEM Non-sport Wheel Specs
18x8
5x114.3
ET +40
OEM Non-sport Tire Specs
265/60-18 32psi is recommended
OEM Temporary /Tire Specs
175/90-18 60psi is recommended
This is excellent info, thanks! Are the specs the same for the 2nd gen FX as well? I know the 20" tires are 265/50/20, but wasn't sure about all the other specs. Want to make sure as I shop for rims I get ones that will fit. Thanks!
Hello Guys,
Does anyone know if we can install 18' on FX45 2003?
I plan to buy some "small" rims specially for the winter tires. It's a must winter tires in Switzerland.
I passed yesterday in the Infiniti Centre Switzerland and they told me: minimum 19' for the FX45, but 18' fit on the FX35.
Thanks for your kind help.
Kan-G
