FX lug pattern
Discussion in 'FX (03-08) - Wheels & Suspension' started by fxlr8, Jul 21, 2007.
  1. fxlr8
    fxlr8 Staff Administrator
    17,961
    770
    California
    None
    FX Bolt Pattern
    5x114.3 or 5x4.5
    FX Factory Studs
    30mm
    FX Lug Nut Specs
    M12x1.25mm
    FX Lug Nut TQ Specs
    80 ft-lb
    FX Centerbore
    66.1
    OEM Sport Wheel Specs
    20x8
    5x114.3
    ET +40
    OEM Sport Tire Specs
    265/50-20 32psi is recommended
    OEM Non-sport Wheel Specs
    18x8
    5x114.3
    ET +40
    OEM Non-sport Tire Specs
    265/60-18 32psi is recommended
    OEM Temporary /Tire Specs
    175/90-18 60psi is recommended
  2. Dr.2K
    11,683
    9
    Santa Clarita, CA
    2005 FX45
    This needs to be a sticky!
  3. fourfifth
    fourfifth Member
    65
    Boston, MA
    2009 infiniti fx35
    Hey I have a question about wheel compatability. I've been shopping for wheels on ebay but they hardly ever mention the fx. What vehicles share the same bolt pattern as the FX?
  4. OP
    fxlr8
    17,961
    770
    California
    None
  5. fourfifth
    fourfifth Member
    65
    Boston, MA
    2009 infiniti fx35
    Thanks for that info....
    It seems like the 5/7 series BMW, Chayenne, and Range Rover (for example)share that bolt pattern, so is it fair to say those wheels would fit the FX.
    Also the two bolt patterns you mentioned "5x114.3 or 5x4.5" seem like about a 3" difference. Can you explain that to me a little... I'm just trying to understand so I don't order the wrong rims...
  6. OP
    fxlr8
    17,961
    770
    California
    None
    114.3mm = 4.5 inches
    make sure you get the proper offset (ET) also.
  7. fourfifth
    fourfifth Member
    65
    Boston, MA
    2009 infiniti fx35
    Thanks for your help.
  8. So does anybody know what the typical offset for the FX35 is? Do you guys norrmally run the same f/r or staggered? I know for Z/Gs it's typically +22-29 for safe fitment and anthing in the teens with a drop would require fender rolling in the rears or camber adjustments.
  9. Dr.2K
    11,683
    9
    Santa Clarita, CA
    2005 FX45
    Hmmm....not sure what is typical as it also depends on the wheel width. But I have 35mm offset with a 10in wheel width and I had to shave the rear wheel wells but I am also lowered. There are many combination that can be done. Also, the tire width will also have a contributing factor as well. The oem is 40mm offset on a 8in width.
  10. hey guys, had a question about wheel sizing...
    I'm looking at these wheels made more for 350z's and G35's, but wanted to see if they be a good sizing on the FX... They are 18x9.5 with +30 offset heres a sample of them
    [​IMG]
    not sure if I can go all the way around, think they fit in the fronts? They have 18x8 at +30 if the 18x9.5 don't fit the fronts... I know they are 18's, but i'm not a big fan of 20s and 22s wheels... Plus I'm here bitching about size 16 tires when I need them for my car I can't think of size 20-22 tires to buy lol... Another thing I won't be lowering the car (maybe lol).
  11. rookie
    rookie Premium Member Premium
    9.5" +30 is 29mm wider than stock, I think you're not the big sidewall bulge kind of guys so you should be able to run this on all 4 wheels. 275-285 you you should be good.
  12. would they stick out? I wouldn't mind a little less than stock sidewall... If I go with HR springs later on you think they would rub?
  13. Chedman13
    Chedman13 iS VIP iS VIP
    9,167
    103
    Illinois
    Nice choice, looks similar to what another member had (Alex)?
  14. Dr.2K
    11,683
    9
    Santa Clarita, CA
    2005 FX45
    Yea they look similar to the volks time attack wheels.
    Like rookie said the specs should be fine to fit the fx and as long as the tires aren't too wide you shouldn't have any rubbing issues.
  15. OP
    fxlr8
    17,961
    770
    California
    None
  16. thanks for the photo fxlr8, Now I really want them on the FX...
    Yeah I'm not going with any crazy tire fittings... As long as they don't stick out because I'm planning on putting springs later on.
  17. CycoDK
    CycoDK Member
    52
    Qatar
    Does FX35 and 45 and all models have the same pattern except from the rim size??
  18. Chedman13
    9,167
    103
    Illinois
    Yes, both the same. Also, you can get FX35's in 20's from the dealership.
  19. Chedman13
    9,167
    103
    Illinois
    You shaved just the rear? I'm going to be doing this soon and wondering if I should shave the front as well. I'll be running 265/40/22 on 22x9 +15mm, which is +38 out (very aggressive), thanks to the advice of Rookie.
    Just preparing while I wait for my wheels to come.
  20. rookie
    The sidewall bulge is the next part after offset that determines if the wheel/tire will rub. 305 on a 10" is decent sidewall bulge, your 265 on a 9" should be less sidewall bulge and less wheel/tire to get near the wheel wells. Fronts, mazzzur pushed his clips up to gain a little extra clearance.
