Ebay "Tesla" Style Center Dash Screen Console
Only downsides for me are:
  • I still can't get my reverse camera to work. Other have though
  • the mic sucks rendering conversations via bluetooth useless unless you're just listening.
are you trying to get your OEM reverse cam to work or aftermarket?
And what About this unit? Is there somebody familliar with it? It should work the same as the big screen only it’s cheaper!5381EE7D-09BE-413A-8D35-32BB2FBCF819.jpeg
For anyone trying to get their oem reverse camera working with these radios I found this website that shows you how to.
https://rrcs.zendesk.com/hc/en-us/articles/360044321591--2006-2008-Infiniti-FX-35-Installation-Note
Scroll to the bottom and you'll see it. Basically you find the correct connector on the car and then tap into the correct wires with a male rca to bare speaker wire
I used this Amazon.ca
They use a pin connector to connect to the car I used posi-tap connectors to tap into the wires instead. They will be negative from your rca cable to the black wire on the car, and positive from your rca cable to the blue wire on the car. My stock camera works now, although the quality is still the same on a bigger screen lol. I will get a new camera in the summer but for now it works.
Also can somebody share exactly how they fixed the static noise issue, I haven't been able to fix that and its driving me crazy already.
Great! Thanks for sharing this. Do you ave any pics of your wiring? I haven't looked at this in several months. I'm curious to know the connection/ports used with the Tesla style radio.
Also I don't know about the static noise issue. I haven't had that problem with this radio, but that often is caused by a bad ground or cross interference from another electrical current. Have you checked your ground connections?
Unfortunately I didn't take a picture, but the connector is easy enough to find and once you match the color of wires in the correct location you'll know for sure it is that connector.
For the static/hiss noise I'm hearing I tried grounding the rca's like someone mentioned earlier but that did not work for me. So now I am wondering if there is a issue between the radio and the factory bose amplifier signals, I was planning on running a PAC ROEM between them to process the signal. Can somebody chime in if they had the same issue and if so what was the fix?
The units have come a long way. I have purchased a unit from Aliexpress.
188.39US $ 50% OFF|2 Din Android 10 Car Multimedia Player For Nissan Infiniti EX25 QX50 Car Radio 4G WIFI DSP CarPlay GPS Navigation No DVD Player|Car Multimedia Player| - AliExpress
FYI all the screens are made by one company in China called Carbar. They are that developed now that their arent many issues and the canbus frame pack is easy to find on Alibaba.
i was able to find a frame for my ex/qx50 for $3.50 AUD... which is like $2.50 USD?
Another good company was this one: 399.0US $ 30% OFF|Tokesla 2 Din Telsa Car Radio Gps Android For Infiniti FX FX35 FX45 Video Central Multimedia DVD Automotivo Players Navigation|Car Multimedia Player| - AliExpress
And this one seems to be the biggest seller: 412.02US $ 58% OFF|TEYES TPRO 2 For Infiniti Fx35 2006 2009 For Tesla style screen Car Radio Multimedia Video Player Navigation GPS Android No 2din 2 din dvd|Car Multimedia Player| - AliExpress
Aliexpress has killed ebay.
Radio Fascia Kit For 2013-2017 Infiniti Qx50 Car Stereo Frame With Wire Harness - Buy Radio Fascia,Car Stereo Frame,Facial Kit Product on Alibaba.com
Sorry $4 USD - less than a Big Mac. Including the Canbus. Which suits the following models:
MURANO 09-10 display screen, dash, w/o navigation system; multi-color display (premium package) INFINITI G25 11-12 (Sdn), display screen, w/o navigation system
INFINITI QX50 14-16 display screen, (dash), w/o navigation system
MURANO 11 display screen, (dash), w/o navigation system; multi-color display (premium package)
INFINITI G37 08 display screen, w/o navigation system INFINITI G37 09-13 Cpe, display screen, w/o navigation system
INFINITI QX50 17 display screen, (dash), w/o navigation
INFINITI G35 07 display screen, w/o navigation system; (4 Dr, Sdn)
INFINITI G37 09-13 Sdn, display screen, w/o navigation system
INFINITI Q60 14-15 Cpe, display screen, w/o navigation system
ARMADA 08-15 display screen, dash, w/o navigation system
MURANO 12-14 display screen, (dash), w/o navigation system; multi-color display (premium package), 4 Dr
PATHFINDER 08-12 display screen, dash, w/o navigation
INFINITI G35 08 display screen, w/o navigation system INFINITI EX37 13 display screen, (dash), w/o navigation system
INFINITI Q40 15 (Sdn), display screen, w/o navigation system
MAXIMA 09-14 display screen (dash), w/o navigation system; multi-color display
Hi guys I purchased this unit last month for $650 I just started installing 2 days ago I have no idea what to do the audio does not work. I have no control over the AC box and the company sent me a video where I have to pull out a 36 pin connector from under my dash. I took out the glove box and cannot find that 36 pin connection any where so I'm in AZ 100 degree weather and have had no audio or AC for days.
Hello, i know this thread is old but i cannot find a solution to my problem. i just purchased one of these stereos and it has android 15 OS. i cannot get the sound to work. everything else is working. i have a 2003 fx35 with factory backup camera and factory navigation. i saw videos of people just simply changing the "AMP" in settings, but that doesnt work for me. first of all there is no AMP in my settings. the only option is the pull down menu from the top and a button that says aplifier. but having it on or off does nothing. any help would be appreciated
i just purchased a tesla style stereo for my 03 fx35 with factory nav and camera. i have ZERO sound. i connected everything correctly even the glove box pin. everything else works. can someone please help
