- Los Angeles, CA
- 05 FX35 RWD
Nicely done.
I also just installed a 10 wire 'grounding gear' kit, & it also includes that same ground to chassis. There are a more points, if you want to add additional grounds. I will post pics later. I've also got all my grounds, including the two coming from that harness, grounding to one bolt at the front of cam, whereas you chose 3 diff points. This is one of gordon's directs. everything should move over to one point, with a supplied longer bolt.
