Totally off thread hijack style here...is your Avatar pic taken in the Rose garden?
Thx again la...u da man. Sorry one more question....when you remove the crank bolt, if I lay the breaker bar on the ground, it should be to the left with the bar handle towards the passenger side correct?? I don't have ramps so I can't do the string tie thing that tchuck did....
If you use the ground instead of the frame rail, you want the breaker bar to be toward the drivers side. Imagine the motor turning clockwise; your bar should be like the hour hand of a clock at 4:00-5:00. Not. 7:00-8:00.
Hey tchuck...I tried the string method and
The bolt wont budge?? I tried cranking the engine
2 times and then checked the bolt, I did this
for five tries and nothing? Any ideas?
Thx man...I'll try the Pblaster tmrw...if that doesn't work I'll take it somewhere...u think I could have caused any damage by tryin this too much??
Cool...I'm gonna pick one up tmrw and swap the batteries and then try cranking it again. Hopefully that'll work...I'd hate to have to take it someone to do it after spending the wknd on it...it's my mission to get this thing off now lol
