Hi all,
I plan on doing the UR pulley set...can anyone post what the torque specs are for
all the bolts...crank, alternator and idler? Can the crank pulley be torqued enough by hand? Or do you need an impact/air gun??
Here's the torque specs you were looking for.
As for swapping the alternator pulley, it's going to be a PIA.
Nothing to hold the pulley from spinning so you can undo the bolt by hand.
You'll need a strong impact gun spin the nut off quick and strong.
You'll also need the impact gun to tighten down the pulley as well.
