Hello ! My friends
I am starting to make the bracket. And I am waiting the factory produces some parts to me!
Because the amount is not many, wating is necessary for me.
I want to show something "How is it to put the female terminal into the connector". This is not a real installation.
Important: There is not inculding white connectors in my bracket kit! (This connector is just a sample. )
Price will be higher , if the kit is inculded connectors.
Release the cover of connector ! Just a little!
Take out the front net cover, then you can see correct side of the terminal.
Put the terminals into the connector from the back of connector
Hey guys, havent been on for a while but saw this today. In doing a quick search it looks like part of the bracket can be bought from the dealer. I don't know how hard the install will be on that part alone. If this works, you will still need to find a way to mount the top/front of the shifter but at least this one mount will line the shifters in place. Might be as easy as drilling and putting a bolt through it.
Part 8:
Usually, I made 5 bracket kits evey time!
But! Now, I only have one sample bracket, others were installed or sold.
I need more time to make more brackets! It is made by machine and handade after work time.
I never sell anythings on ebay, so I must prepare a lot of things to do it.
Forgive me, I can't make it faster.
About price, it is going to be $100~$120.
Here are photos about paddle connectors and part of the bracket.
http://plus.google.com/107211586850797072584/photos
---------- Post added 01-28-2014 at 12:07 AM ---------- Previous post was 01-27-2014 at 11:59 PM ----------
Q: How will the wire hook into the back of the control box?
A: I don't have any record, so I need time to do it.
Q:Will it be just two wires with the right pins plugged into the existing connector?
A: Not really. Two wires(green and orange) are pluged into the connector behide control box.
The other two black wires are connected to the ground.
Okay...so now you're changing the kit to not include the paddle connectors? If I'm not mistaken, you did indicate this was included in your post above for the price range of $100-120... I don't need the connector to the A/V box, just the paddle white connectors.
