1st gen you can take off the wheel well covers (at least half way) and all the bottom covers, then turn the wheel in either direction to get to bulbs. Its a bit of a pain you have to squeeze arms in there. if there is more needed you can remove the fog light assembly and mess with it outside, then put it back in after.
I swapped mine for halo/projector combo, but I want to change out the bulb for LED or HID. this HID you're using with the standard bulb/reflector housing right?
How does that halo projector working for you? There are feed backs here of low light output.
---------- Post added at 10:01 AM ---------- Previous post was at 09:55 AM ----------
try switching the wires around?
+1. If you are using the Mori, there is an extra wire with 2 pin type connections from the bulb that you don't need. Make sure to take them out as it has no function.
