The Random Question Thread
On the Canadian models it is lit bright when you turn the car on, then goes dim when the lights are turned on
Aren't the DTRL on the Canadian models the fogs?
---------- Post added at 12:43 PM ---------- Previous post was at 12:40 PM ----------
Ohhhhhhhhh nvm just saw it's first gen lol. my bad. Carry on!
Went to my Transmission mechanic today to do a quick Trans Fluid Change.. and he recommended that I don't it
He says that my car has lots of miles to the point it wouldn't be beneficial to drain and fill the the fluid.
Does this make sense..?
He's probably talking about a hi-power flush?
Totally OK to flush out the old oil, just dont do it on a machine. Just run it through. If you're worried, do a drain & fill for the next few times you do an oil change
It was just going to be a drain and fill
I'm at 219,6XX miles
I'm going to keep it forever... Lol, it's an 06.
It was last done, I think at 120K or 130K
And I believe the guy is in his late 30s
Sent from my iPod touch
Woke up this morning with a 4 Sq ft puddle under my car.. Looked like water but had a small tint of red on some areas.
I checked for any leaks from under and saw the small bracket holding these 3 small hose lines (EVAP?) was wet. Is this normal like the puddle from the A/C?
This is located on the passenger side right next to the front wheel
Sent from my SGH-M919
---------- Post added at 04:57 PM ---------- Previous post was at 12:47 PM ----------
Great. The people who did my transmission fluid probably didn't tighten something :/
Hello guys!
Has anyone tried these HID bulbs from this company? If yes, is this a good brand? Anything out there that is comparable or better without breaking the bank?
http://www.ebay.com/itm/120918919007?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
Thanks in advance.
Never tried them. I would go with Osram's CBIs. Not much more expensive but very good quality bulbs with pure white color.
Here's one:
http://www.ebay.com/itm/2-xGenuine-...e&pid=100005&rk=3&rkt=6&sd=181707512684&rt=nc
Nnaji, that moisture underneath seems normal, but the stuff on the ground looks like coolant to me, although the red suggests ATF. I assume you used the Nissan fluid for the change, and your coolant is yellow/green?
What color is the coolant in your overflow?
Thanks Jason. I've heard good reviews from Osrams.
---------- Post added at 04:21 PM ---------- Previous post was at 04:19 PM ----------
I love them. I haven them in my car for over two years without any issue.
Thanks Andy. I guess, you can't go wrong with any recommendations coming from Handy Andy!!! :good::wink:
Yeah I used the Nissan grade ATF. But yeah it was actually the ATF leaking.. Thing is after they removed the pan to inspect it, you have to replace the gasket and I guess they reused the old one. All is fixed now, since they replaced the gasket. I also heard elsewhere that the screws should never be reused.
Random, but is there another brand of ATF that is better than OEM's?
