On the Canadian models it is lit bright when you turn the car on, then goes dim when the lights are turned on
Ordering my struts from parts geek, both assemblies.
Are there any strut accessories I need to order?
Honestly, I'm not sure if the assembly comes with the mounts..and I think you'd want to get new mounts with your struts.
http://www.partsgeek.com/catalog/2006/infiniti/fx35/suspension/strut_assembly.html
Hello guys!
Has anyone tried these HID bulbs from this company? If yes, is this a good brand? Anything out there that is comparable or better without breaking the bank?
http://www.ebay.com/itm/120918919007?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
Thanks in advance.
I love them. I haven them in my car for over two years without any issue.Hello guys!
Thanks in advance.
Nnaji, that moisture underneath seems normal, but the stuff on the ground looks like coolant to me, although the red suggests ATF. I assume you used the Nissan fluid for the change, and your coolant is yellow/green?
What color is the coolant in your overflow?
