Once you buy those camber bolts, you need to have the sub-frame holes that front lower link and rear lower link slotted/elongated using the template that comes with the kit to allow for the +/3 degree clearance. It all depending on the Firestone you go to if they willing to do that.
In order to slot the sub-frame, you need to undo the end of the shock that bolted to the front lower link so that it can be slide out of the way so that you don't slot the link hole. You only need to slot the hole on the sub-frame). You will have to completely remove the rear lower link (spring bucket) in order the slot the rear lower link hole in the sub-frame.
