Here is how it looks like. Notice the hook under the aluminum strip is broken. Also note I use an exacto knife to cut the middle rubbery part to separate it.
If you cut the middle rubbery apart first and then try to work the hook off. You might get it off without breaking it. I glue my back and it been staying in good.
---------- Post added at 10:19 PM ---------- Previous post was at 10:18 PM ----------
I tie a bunch of rubber band around it to hold for the adhesive to cure.
Same here I just ripped mine out but then replaced it with a piece of chrome molding strip to match the plate and then got another shifter, but the molding still holds strong on the original shifter. It sits on my dresser.
THe fxr is discontinued. it is replaced with the tsx lense. If you have the recalled headlights, if just leave it in or else you will have to mess with the shield. To find out if you have pre or post, Post will have a metal bracket that you have to take off to get to the ballast. Thats what i found when i had a set of post and pre's.
Okay so you don't have the extra two little reflector pieces. Unfortunately I cannot find nor remember whether that means they are pre or post recall.
I am sure somebody else will pop in and inform you.
If I was asked to go off the top of my head I seemed to remember the ones without the V pieces to the reflector were post recall... Which means you would need TSX-R lenses.
FX-R Lenses are for Pre-recall. Although people have found out that if you order the wrong set, you can still make them work just as well by playing with the reflectors...
