The Random Question Thread
It sounds bad IMO, my hommie had a g37 with stock exhaust and the rasp and hiss sound was annoying so he just took it off.
---------- Post added at 09:36 AM ---------- Previous post was at 09:35 AM ----------
What kind of hissing does it make? Like a blowoff valve?
Lol naw far from it
That oil pulling method sounds interesting, but I have never tried it. What would you use , cocoanut oil, sesame oil.
The two most popular oils are both pure sesame oil and sunflower seed oil.
There have been some negative reviews about sesame oil staining the teeth for some.
Coconut oil can be used. I read somewhere that it is not AS effective, but it works and it's sometimes preferred over the other two because of the coconut extract.
I'm actually thinking of buying a jar of coconut oil from Amazon. Not only does it help whiten teeth, but it provides healthier gums, fresh palette, and breath.
Good info, thanks Gold, I might check out our health food store and see what they have.
---------- Post added at 09:51 PM ---------- Previous post was at 09:47 PM ----------
Do you put tpms sensors on aftermarket wheels
Some people do, but you have the added expense of 4 more sensors then you have to get your car re-calibrated to recognize the sensors each spring and fall when you change out wheels.
I just run sensors in my winter wheels because I don't mind checking the pressures manually in the warmer summer months.
Since the Q50 has been released... does this mean it will be available as a loaner?
Hmm, a Philosoraptor-type question.
Yup I would say so
---------- Post added at 11:10 AM ---------- Previous post was at 11:04 AM ----------
Since the FX is now going to be called QX70, will the 1st gen and 2nd FX's lose their value due to this change?
Or will they become classics :)
It's not a bad system to start with. just don't mount the speakers like those people on Amazon did:rotfl:. Are you buying a receiver also?
