so I have the bracket from my oe cats I was thinking of going tomorrow and having them weld the 2 small hinge like things with the screws on them to the HFC's so I can mount the bracket. Is this what you are talking about?
Yep.
UP. so lost what length extension i need for my nismo. on the g35 forums says 6 inch here says 3. anyone can clear this up
OEM y pipe + 1 extension afterwards or
Kakumei/Megan y pipe + 1 extension afterwards or
2 extensions before + Nismo y pipe
http://mynismo.com/products/?id=4404
Tips need to be cut and extended to your liking, no way around that.
negan + extension. Need some clarification of how long of extension I need .
Why don't you just buy the extension? I posted the link above. You just need one of them. I don't know the exact length. Are you ordering just a stainless steel tube then cutting to fit?
Random or not, any way I'd like to know if the upper and lower plenum can be removed as one complete piece...? Reason is, I need to replace the valve covers due to oil leaking through spark plug seals. any help is greatly appreciated...
Does anyone know if they just sell the resonator pipe alone (I know they do) but I mean a high flow one and if so where can I get it???
