If you don't want to venture down to Chicago for programming. You need to have your own usb cable to download maps. I'm sure once you buy the cable from Aaron from Unichip, he'll help you out with the software.
Yep it's Q versionIs it the Q version? You need the license if you want to tune yourself. If you just want a standard tune to roll with, you can use the free version of the software for long enough to load it. As for getting the maps, I'm sure one of the nice members here can hook you up........![]()
Yep it's Q version
PS TCHUCK, did you wire the 350Z unichip to your car, right? If so, what exactly needs to be changed? Let me know
Ok, then it's basically Plug&Play between FX and 350Z/G35, right?
Got an update here folks! So far Its been tested on my 80gig video.
1- Take your ipod, and make sure its on.
2- Plug it in to the FX gateway.
3- Immediately hold the play/pause button on the Ipod until it goes to sleep (a couple of seconds).
4- Then press the menu button on the Ipod. It will wake up, and still be under the radio's control, but you now can scroll thru the ipod and play whatever you want! Plus the song up/down on the radio still advances songs!
Anyone know where I can get a set of outer plastic covers (lens?) for the 1st gen headlights? I just need the plastic, have a set o lights but the were VHT'd and are very hazy. Thanks
Bumpity
Maybe the bulb or a wire giggled loose?
It's all about the lighting. There was a recent ebay ad from a dealer that showed a set of tails that looked blacked out, but they were just normal smoke chrome. Also, turbo discovered that the dark chrome has variations depending on the manufacturing process. He had two side by side and there was a clear difference in the darkness.
