- Toronto, Canada
- 2008 fx35 AWD
so ive been researching on spark plugs and wanted the best for the fx. so the most popluar one is the LFR5AIX-11 Iridium IX Spark Plug??
...As you apply brake one of the caliper is not catching the rotor causing the a "slip".
If you mean spacers, 25mm all around will get you really really close to what you want.Im looking for 100% flush / maybe slight poke on the rear on my stock 18 rims. Eventually might get 20's. what would i need to achieve this without rubbing? common is 25ft on 25 back i think.
Ha, your iForged Imola 24" setup on OEM suspension was a little more then 2 3/4" gap. I got picture to proof it :smile (2):
