I saw the comparison pics and it just hit me that the prerecall lenses are clear in the first place (a 9 out of 10 on the "clearness" scale) and one doesn't need to replace them unless they want a 10. The post recall lenses are significantly cloudy (like mine) and NEED to be replaced if you want a better output/cutoff. So to sum it up, visibly cloudy = TSXR swap needed. If you can't tell wether they're cloudy or clear, its likely they're clear prerecall lenses and can be swapped to FXR to get even clearer. Right?
I think it's, post recall, prerecall, TSXR/FXR. But the TSXR will not fit prerecall same with FXR not fitting postrecall
Ok, so are the "clearness" of the lens are in this order?
Post re-call lens > TSXR lens > Pre-recall lens > FX-R lens
Left being the cloudiest
Right being the clearest.
Just buy the TSX-R lens and you will have the BEST lens available for our car. Forget about all the "Pre/Post" lens!
tsx lenses fit in both housings?
Yeah, but they fit fine!I thought there was some grooves that were different in pre and post recall
I've been thinking of getting the lightwieght racing pulley set but dont know if its worth the time, money, and effort. Does anyone know the pros and cons for this? Is it worth the money?
I have a random question:
How much wood could a tchuck chuck, if a tchuck could chuck wood??
