You have to use special heat resistant insulation for that spot. Jumbo has the dynamat version iirc.
Sent from my BlackBerry 9850
Got it. I was hoping to carefully pop off the retainer rings, cut pieces of the dynamat to fit inside the triangles then replace the OE padding (stealth insulation).
