- 2004 FX35 AWD
- Name
- John Green
Oil Cooler O Ring Repacement DIY----
Reference thread: https://www.infinitiscene.com/search/1/?q=9377-Oil-Cooler-Gasket
Since these seem to be an issue with oil leakage I decided to coat the new O Ring with
Loctite 518 Gasket Eliminator a flexible sealer to hopefully never have this issue again---
Remove center through bolt with 22mm socket or wrench-----
Pull back oil cooler and you can leave the hoses attached--Remove old O Ring and wipe everything down good. Install new O Ring (w/sealer optional**)
Reinstall oil cooler and torque Oil Coller retainer bolt to 36 ft lbs-----
Done----(NO MORE LEAK
