Oil Cooler DIY
MTN FX
Mountain Man
Premium
Big Bear City,Ca.
2004 FX35 AWD
John Green
Oil Cooler O Ring Repacement DIY----
Reference thread: https://www.infinitiscene.com/search/1/?q=9377-Oil-Cooler-Gasket
Since these seem to be an issue with oil leakage I decided to coat the new O Ring with
Loctite 518 Gasket Eliminator a flexible sealer to hopefully never have this issue again---
Remove center through bolt with 22mm socket or wrench-----
Pull back oil cooler and you can leave the hoses attached--Remove old O Ring and wipe everything down good. Install new O Ring (w/sealer optional**)
Reinstall oil cooler and torque Oil Coller retainer bolt to 36 ft lbs-----
Done----(NO MORE LEAK:rolleyes:)
that filter is huge, my mobil 1 is 1/4 of that..
It's for the FX45 K&N 1010. It;s a little larger than the one for the FX35.The K&N 1006 is even a little larger but NAPA didn't have that one in stock.---
See this thread----
///102943&postcount=3
OMG.......36 ft / lb torque? Do you think the slight leaking could be caused by regular tightening with the 1/2 socket wrench? 36 ft lb sounds like i should have used a cheater bar to tighten this!
Howdy. I replaced my gasket last summer and it started leaking again. I nudged the torque up to 40#, no good. Think it would work to take it apart, clean it up good with solvent and try to reseal it with the sealer? Or should I just get a new gasket and sealer? Thanks for your feedback.
Thanks for the write up John. At 108k miles, mine just started leaking. Called Infiniti dealership, they wanted $10 for gasket. Called local Nissan dealership, $4....lol.
Keep an eye out for this when you get to around 100k miles guys. I am at 95k and this leak just got the best of me. Luckily it's only a $4 fix!
Thanks Man!
I Went to Inifiniti Dealer here in Denver quoted me 190.00 to do wtf??
Read your post did it in 30 minutes and for 5.70... Thanks!
Nissan has also made a bigger "o" ring that supercedes that one
part # 21304-Ja11a
part # 21304-Ja11a
Nice. This will comes in handy one day. Knock on wood! I'm at about 120K miles.
Mtn's oring is red, when I went to Nissan they gave me a black one. They say the black ones are the new orings.
