Andy and others,
So for a few months now when I fill up it doesn't quite reach all the way to the top. No big deal, but figured I'd maybe try to address it. Everything else works fine.
I took it to the dealer and they said this doesn't fall under their TSB that the new FXs were having issues with, so this particular issue I was thinking was things getting dirty similar to what this DIY is all about.
I asked dealer to quote me for 2 sender replacements:
O-ring 17342-CE800 $17.02 x 2
Bracket 17045-1EA0A $15.38
Sender 25060-1CB1C $160.80
Sender 25060-1CB0C $160.80
Labor $113
$484.02+tax
I was going to try the DIY myself but worries me a bit about the issue you, Zebra, and some others have been having. I guess I don't want to make things worse as the slight lower amount after full refuel is not a big deal, but would like to fix if it's simply this cleaning. I'm also a little hesitant to use the eraser, thinking a qtip with distilled alcohol, or maybe throttle body cleaner would be better
Any updates to Andy, Zebra, and others if they are still having some issues? Not sure if I should do this to risk it making things worse than a little annoyance right now.
