- Portland, OR
First off, WTF. How do you know so much?...
I don't know that much. I know the few basic rules of audio (impedance/wattage/current draw/heat relations), I have the schematic (thx Andy), and I am well versed in reading electrical drawings. We are however rapidly approaching the extent of my knowledge and usefulness...
Will the Kicker woofers hit harder than the Bose woofers? I'm assuming the answer is yes, but I have no idea on the specs of the Bose woofers. If that's the case, I'm ordering the Kicker ones.
Theoretically yes, though I couldn't find any specs on the Bose drivers either. The facts are that the oem Bose amp is rated at 100w and it powers two drivers rated (and labeled) at 1ohm each, in parallel. That would imply a 50w @1ohm rating for each of the woofers. Bose isn't exactly known for over engineering their stuff, so it's safe to say that even if the drivers are more capable than the amp, it's not by much. Bose is also famous (notorious?) for using mediocre drivers in very well engineered enclosures to get above average results... 2+2+2=Kicker woofers>Bose woofers.
I have this thing running:
Digital Equalizer with SUB woofer output
And I think my cousin (doing the install) ordered this too?
http://www.kicker.com/zxsum8
And your are right, my door speakers come with cross overs:
http://www.alpine-usa.com/product/view/spx-17ref/
So can I still buy an aftermarket center speaker and throw on in there with all this crap, even though I lost the Bose Amp?
Soundstream - Do you want to use this for the sub alone or the whole system?
Speakers - Awesome. You'll need to power each x-over with one of your amp's output channels, then connect the pairs of drivers to the x-overs. No sweat.
Kicker zxsum - This is the part where I give the disclaimer that I am not a pro stereo installer. That said, I'm a little confused as to why you need this thing. TBH I don't even think it will work at all... It basically allows you to use the speaker level signals instead of the low level outputs from the head unit. (For head units without RCA outputs) The thing is, the Bose head unit has four low level outputs and your amp has four RCA inputs, so you could just connect them directly and bypass the Bose amp entirely. To use the zxsum you would need to intercept the signals AFTER they leave the Bose amp, which will leave you with the Bose processed ten channel mix, and the zxsum doesn't have ten high level inputs. It has eight. This means that the "summed" signal will be excluding the whatever sounds Bose has determined should be sent to the center channel and the subwoofer channel. (because you are picking up the signals on their way out of the Bose amp.)
Unless the low level outputs from the head unit are some connection type other than RCA, I think you can simply connect the four HU outputs to the four inputs on your amp and be set. You'll be bypassing all the Bose processing and reducing your equipment list by two pieces.
I could totally be missing something obvious here, IDK. Feel free to show this post to your cousin and see what he says.
---------- Post added at 12:05 PM ---------- Previous post was at 11:57 AM ----------
So you think I should get the newer one? The older ones are almost 50% off vs the newer ones.
As far as I can tell there are three differences; The color, the size, and the frequency response range.
Color - It's up to you. I prefer black personally but I wouldn't pay two extra pennies for it vs silver.
Size - Both will still fit, and both will require slight modifications to the stock sub enclosure.
Freq response - You'll probably never notice the difference between a 25Hz rating and a 30Hz rating. Both will reproduce a 25Hz signal, but the old drivers will do so at a very slightly lower volume. Again, you'll probably never notice.
I'd get the old version.
