Holly crap! Tim, you opened up my eyes and ears on audio components setup! I'm the biggest novice when comes to car audio. I'll keep my eyes and ears out on this post. Can't wait to hear Ed's setup.
Maybe I'm the bad influence on you now=) I'm hoping this audio systems blows us both away, if so, you'll know exactly what to buy and how to wire it.
My cousin keeps repeating he can add tweeters to the center, but 100% not necessary because of the door and front speakers and a waste of money.
I'm with Jonas though -- I don't like losing anything=)
---------- Post added at 10:18 AM ---------- Previous post was at 09:47 AM ----------
Tim -- I just found these:
http://www.crutchfield.com/S-PH6sVu...r-10CVT654.html?tp=111&tab=features_and_specs
The new model is a little smaller:
Top Mount Depth (inches) 2 7/8 vs 2 13/16 (2.875 vs 2.8125)
Cutout Diameter or Length (inches) 5 9/16 vs 5 1/2 (5.5625 vs 5.5)
So you think I should get the newer one? The older ones are almost 50% off vs the newer ones.
OLD MODEL
Size 6 1/2 -inch
Impedance 4 ohms
Cone Material Injection-molded poly
Surround Material Santoprene rubber
Ideal Sealed Box Volume (cubic feet) N/A
Ideal Ported Box Volume (cubic feet) N/A
Port diameter (inches) N/A
Port length (inches) N/A
Free-Air Yes
Dual Voice Coil No
Sensitivity 84.6 dB at 1 watt
Frequency Response 30 - 350 Hz
RMS Power Range (Watts) 50-150
Peak Power Handling (Watts) 300
Bottom Mount Depth (inches) N/A
Vas (liters) 9.28
Fs (Hz) 53.9
Qts 0.667
Xmax (millimeters) 0
Parts Warranty 1 Year
Labor Warranty 1 Year
NEW MODEL
Size 6 1/2 -inch
Impedance 4 ohms
Surround Material Santonprene rubber
Ideal Sealed Box Volume (cubic feet) 0.2
Free-Air Yes
Dual Voice Coil No
Frequency Response 25 - 350 Hz
Top Mount Depth (inches) 2 13/16
Cutout Diameter or Length (inches) 5 1/2
Vas (liters) 9.28
Fs (Hz) 53.9
Qts 0.667
