I just tried to find that 16pin connector and could not find it. It is not in the area where the radio is. The 16pin connector that is there does not have the correct color wires on it. The only area think it could be is wherethe steering wheel column is.Yes, just follow the cable, you'll find that 16 pin connector
Here is the connector, just follow the the cable down and you will see that 16-pin connector kinda hidden begin the dash on the right side(sorry not the best pic):
It worked!!!!!!!! Thanks for taking the time to take your dash apart to show me the cable. I even looked at that connector but not close enough. Everything works now. Thanks for your help.
What a great community. :good:
Can you provide more pictures of work done?
The website( www. axxessinterfaces.com) for Metra AXXESS ASWC-1 instructions for 2005 FX35 doesn't exist even their tech support has no clue which pin in 16 pin connector and what color in the stock harness I can tap the Gray/Red and White/Green wires from the AXXESS ASWC-1. Does any body here from 1st gen FX35/45 knows or done upgrading their stock with after market stereo? Video on 04/05 Nissan Maxima or 05 Nissan Quest in YouTube is not the same PIN and wire color with my 05 FX35.... See 16-pin(10 pin at the top and 6 pin at the bottom) picture here of my vehicle.View attachment 318106 The website( www. axxessinterfaces.com) for Metra AXXESS ASWC-1 instructions for 2005 FX35 doesn't exist even their tech support has no clue which pin in 16 pin connector and what color in the stock harness I can tap the Gray/Red and White/Green wires from the AXXESS ASWC-1. Does any body here from 1st gen FX35/45 knows or done upgrading their stock with after market stereo? Video on 04/05 Nissan Maxima or 05 Nissan Quest in YouTube is not the same PIN and wire color with my 05 FX35.... See 16-pin(10 pin at the top and 6 pin at the bottom) picture here of my vehicle.
