Damn I need this too
---------- Post added at 02:54 PM ---------- Previous post was at 02:42 PM ----------
Anyone from the Chicago Area want to help a brother out that has no tools?
Sounds like possible hub bearing issue see this thread---I'm getting front-end wheel noise it seems when going 40+mph - I'm wondering if this would help too?
Any chance of getting the pictures updated? I can host them if you'd like.
Thanks!
any pictures? i'm noticing the same prob. just got a wheel alignment, which was off since it's been dropped on H&Rs, and wheels balanced, but noticed a slight shake on the highway. want to try this out to see if it helps!
same here
My C bolt was loose so I loosened it more so i can tighten the D bolt (a/c belt was loose).
So for you, loosen C bolt in order to tighten D bolt, then tighten your C bolt again.
Same for the A/B bolts......
i looked at the p/s pulley and it was wobbly, do you think this could be the cause?
All I can is OMG.
I didn't drive my car for good 2 months and I took it for a spin today and I was really freakin' annoyed with the vibration of the steering wheel. I thought it was the alignment or the tires. Since I can't address either one of them at this hour, I decided to give this a shot.
I turned it to the point there it was firm (about a good full circle) and took it for a spin. I got a big smile when I let the steering wheel go to check if it worked around 60-70 mph and noticed that there was absolutely no vibration. Man, Car feels brand spankin' new now.
I should've done this long time ago! This thread is a winner!![]()
