BBK GB feeler thread
Hah - It's crazy how much clearance I have. I ran a quick template based on Mr. Chedman's advice and knew I had room but never knew the Gap would be so big. I think I could fit a full grown schnauzer in there.
Yeah you do need spacer to clear stock 20s. At least 10mm spacer is needed.
In case this ever happens or someone else drives your car.
1) Someone else driving you car, have them call you if you get a flat and not to do ANYTHING.
2) Your spare MIGHT fit on the rear without a spacer, I need a few mm, so I throw on a bolt-on type 25 mm spacer in case. The FRONT, definitely will scratch the caliper paint. Throw a 25 mm spacer (at least for AP Racing 6 pot), and you are good.
3) If you don't have a spacer in the car and you have a front flat tire, jack two sides up and swap a good rear tire to the front and put the spare in the rear.
I want GT-R's in hypersilver =) 10.5 all around to copy lance and his hard work getting a full matching set.
Finally, Two days of sunshine in Seattle and a wash for the FX - A few shots W & W/O the BBK visable.
WTF!? When you replied I could see all three images again :confused.:....can you see this one?
No sir
---------- Post added at 11:20 PM ---------- Previous post was at 10:32 PM ----------
Well i guess we wont see those pics today Lance. Im heading to bed. Hopefully theyll be up tomorrow morning. 'Nite all.....
