Gave it one last hand wash + polish and handed her over to the new owner. It's a sad day, gentlemen. For the first time in just over six years I am officially FX-less. :(
You had a hell of a run in those 6 years and the wealth of info you provided here will carry on so much longer. Your iS family is always here for you, FX or not.
Working on cleaning a little rust from the luggage rack bolt heads... Not bad, just starting to show discoloration - using WD-40 and small brush... Rather not take it apart.
Lowered truck and tookk off plastidip im rubbing on dips ....Any one know a fender rolling spot near bx ny that works on fxs?? Been to two places wont do it cuz fender lining is too thick and will "lose shape"
check out e46keith, you can reach him through instagram. Located in queens and awesome work
http://instagram.com/e46_keith
edit - i actually just saw you on his instagram so i'm assuming you've been there. Keith couldn't roll your fenders?
trans cooler, trans filter and oil change
---------- Post added at 10:08 PM ---------- Previous post was at 10:06 PM ----------
I also did the electric fan conversion. Has anyone else run into the problem of the lower radiator hose hitting the driver side fx35 fan?
