You probably forgot. You knew about it at the time.
So I can only get the front coilovers installed today. Spent a lot of time trying to adjust the height.
I rounded out the lower shock 17mm bolt tonight, can't continue tonight.
did the same thing while installing springs and stayed up till 2-3 AM stubbornly trying to get it off with only a flashlight as the source of light. Unfortunately no success so I drove around for a week with the rear lowered, front at stock height... "stu's reversed raked special"
did the same thing while installing springs and stayed up till 2-3 AM stubbornly trying to get it off with only a flashlight as the source of light. Unfortunately no success so I drove around for a week with the rear lowered, front at stock height... "stu's reversed racked special"
LMAO!!!! same thing happened to me on my h&r install.. I dove one side stock and the other lowered lol. Went to alignment guy and he loosened it, better leverage!
Well, I didn't do any cool mods or anything, but my FX spent the day at the dealer for the following stuff:
1) Bubbling dash replacement. They did a FANTASTIC job! No marks, scuffs, or rattles. My dealer rocks.
2) Replaced rear wiper motor as the wiper barely moved and made a horrible noise.
3) Coolant flush
4) Odometer recall
I was SO nervous about the whole dash replacement ordeal. However, as I inspected it when I picked the FX up, it looked great. I was dreading finding any scratches or other marks, but the job was perfect and my dash is new :) I could not be any happier with my dealer. That $50 I spent for the Infiniti 7yr/100,000 mile warranty (my FX is a CPO) sure paid off as the wiper motor was over $500.
This is how it looks with front Kido coilovers at 30.25" from ground to top of the wheel arch and the rear is 31.25".
^ Wow, looks good. Boy, do I miss that look. You plan on lowering the rear or do you like that raked look going on?
Haha, I don't like that look. I was planning to install the rear last night until I rounded out lower shock bolt. The rear still on H&R. Now I need to figure how to un do the rounded out bolts.
Andy you gotta stop being the first at work all the time.. ;)
By no mean to be the first at all :smile (2): Just happen that my driver front wheel bearing was failing, so while doing that mind as well put the coilovers on, right?
Galaxy S2 on
Installed the kinetix intake and got a check engine light after I started it the second time. I need to get an inspection done soon. Should I do a battery reset?
You probably have a vacuum leak. That plenum shouldn't throw a code if installed correctly. Check all the connections and be sure the gasket is properly aligned.
