Received my 25mm H&R spacers in the mail today. Debating whether to install them today or wait to the weekend. The box is in German how do you know if they sent me the 25mm?
Is there something special that I need to do prior to installing the spacers? I saw a video where some guy uses sand paper before installing them
that "something special" is: go get a lap dance, a few beers, walk home and install them. once done, pics are a must or it never happened :tongue (2):.
cheap plastic trim infiniti used. COmmon problem for us. What makes me mad is im a month and a couple weeks over my warranty
Its not covered by warranty, I tried to get mine replaced. I have cracks on both the passenger & driver side. Plus I have a great service writer and she couldnt get it covered.
so finally finish the install of the H&R spacers sorry for the pics it was dark when i finished i thought i was going to be quick but a few neighbors came out and were talking so i was a little distracted. They wanted to know what in the world i was doing again the my FX.
Before
After
---------- Post added at 06:42 PM ---------- Previous post was at 06:41 PM ----------
i will try to get better pics this weekend
Tell your neighbors "I got more important s**ts to do than talking to the likes of you"! Looks good man, are happy with the flush effect? No poke in the rear? =)
Yes I'm really happy with the flush effect. That was once of the big mods I wanted to do. Now I'm thinking about the paddle shift mods and the BBK.
Andy, I never noticed you had floating rotors. That's an expensive set of two piece, floating rotors with anti rattle springs and spacers you have there. Pretty sweet.
Replace my front driver side hub bearing. Had to buy the ABS Wheel Sensor. It seized in there so bad that I have to drill it out.
You probably forgot. You knew about it at the time.
So I can only get the front coilovers installed today. Spent a lot of time trying to adjust the height.
I rounded out the lower shock 17mm bolt tonight, can't continue tonight.
