Seriously, I highly doubt an high output alternator is needed for the running e-fan.
the fan is going to add no more load than the average fx35 see's, so I wouldn't worry about the alt...
The FX is pretty nibble now then ever even more with the +2
I had to replace the temp sensor because we think it went bad. After removing the old one, this is what it looked like underneath. This does not look normal. There is too much corrosion in a short amount of time, less than two months. It looks like it came off a long-lost sunken U-boat from WWI or something. Any input?
just curious, did this conversion save you any weight?
Is that an OEM sensor? Which coolant are you running?
Are you running an OEM radiator? Looks like how a copper radiator on a different car affected my temp sensor. Other than that, yes, electrolysis which might mean that your wiring for the t-stat and/or gauge if you're using one isn't grounded properly
