FX45 electric fan conversion
Yeah, I think it just my alternator and battery was on it's way out. Luckily, it happened during the eFan install process and not on the E-Way.
---------- Post added at 02:38 PM ---------- Previous post was at 02:37 PM ----------
So I just went the Ed route and upgrade the Alt and Battery
(Optima Red Top) anyways.
---------- Post added at 02:39 PM ---------- Previous post was at 02:38 PM ----------
The FX is pretty nibble now then ever even more with the +2
Dakota settings thanks to Andy:
F
LON: 175OFF: 173
HON: 180
OFF: 178
DLY: 0.50
FAN: 2
SND: NO
I had to replace the temp sensor because we think it went bad. After removing the old one, this is what it looked like underneath. This does not look normal. There is too much corrosion in a short amount of time, less than two months. It looks like it came off a long-lost sunken U-boat from WWI or something. Any input?
Is that an OEM sensor? Which coolant are you running?
Are you running an OEM radiator? Looks like how a copper radiator on a different car affected my temp sensor. Other than that, yes, electrolysis which might mean that your wiring for the t-stat and/or gauge if you're using one isn't grounded properly
just curious, did this conversion save you any weight?
Not really, the OEM clutch fan weighs about 6.66 lbs and the OEM electric fan replacement weights around 10 lbs. But the whole point was to reduce the spinning mass, wear and tear on the engine, improving efficiency, and freeing up a little extra horsepower.
No, its a Dakota sensor; part of the conversion process. I'm using Prestone 50/50 premixed coolant.
Yes, I'm using the OEM radiator. By process of elimination we have narrowed it down to an improper ground for the temp sensor, yesterday. Your statement really solidifies what happened in the pic above and the only thing left to check; the ground for the sensor. Thanks K. :search:
