Status
Not open for further replies.
I'll ask Andrew to give you a ring when I'm there in the spring and you can check it out. Can't wait for my Viper to look like new again!
What can I say. I'm pretty pissed. The club politics and egos can get pretty childish. Sorry 'bout that!
Really looking forward to getting out there in the early spring. Damn snow!
its ok, no need to get mad about the viper forum. theyll all be jealous when you roll up at a viper meet in the spring & your cars shining better than anyone else!
feb is the worts month of the year! screw snow, i hate it!
---------- Post added at 09:21 PM ---------- Previous post was at 02:56 PM ----------
Chrysler 300C is finished!
here are 2 teaser pics. i bet you can't wait till i post the writeup for this one huh?
Pebbles approves!
front passenger door, thats the molding & lower portion of the door
before
after
ill reply to all PMs tonight
we are not all booked up for tomorrow.
if you want aything done CALL the shop or send me a PM tonight
thanks everyone
---------- Post added at 10:03 PM ---------- Previous post was at 12:19 PM ----------
thanks everyone
thats alot of wheel gap! :eek:
well be open on monday which is presidents day. why should we be closed? becuase its a holiday? nahh
A3 that underwent a full exterior clear coat correction this week.
i have to finish putting together the pics & then the writeup will be posted in a couple of days.
4. & 5. under the door handle
4" orange pad, P21S foam applicater pad to hold up the door handle, compounding with M105
6. under the door handle after M105 compound only
detailers in the UK are talking it up about Finish Kare FK1000P Hi-Temp Paste Wax
this was taken from www.detailingparadise.com a UK detailing website that im a member on.
This was a 335i done a week ago by me, car got polished with final finish to remove some light swirls, went over it with HD Cleanse after and gave it 2 coats of FK1000p. Posted this over at DW and cliosport.
on the Finish Kare website they list it under the marine care products section. that would explain the big white shark on the packaging lable i guess.
here is the information about the product, taken right from the Finish Kare website:
DESCRIPTION: FK's # BWM 1000 is made from a blend of synthetic waxes to obtain a high degree of consistent quality. The most important attributes of this wax blend are hi melting points and greater hardness than natural waxes. Thus, the resulting film provides not only the high gloss but resistance to wear from heat, water & other natural causes. California VOC compliant. It is great for all painted, chrome and fiberglass surfaces found on Marine, Aircraft & Automotive finishes. It is easy to use and easy to wipe off.
the only thing that seems to be incorrect is theyre claim of an easy on easy off experience but users whove left reviews on autogeek.net have had the opposite thing happen to them while applying & removing this wax.
reviews taken from autogeek.net:
fk 1000p, February 04, 2010
Reviewer:
andreas papadopoulos
exelent product ,very hard to buff off but the results are create... its like you add a layer of clear coat on your car.. works better on white coulors,,
Great Value, November 02, 2009
Reviewer:
Ed H
Hard to find a better product for $16. Looks like you put another coat of clear on your car. Works great on glass too and is very durable. Two thumbs up in my book.
makes bugs/bird bombs slide off car!, October 15, 2009
Reviewer:
Lori
In my experience, this isn't the very easiest wax to buff off, but it's not the most difficult either. It is likely my application technique as most people have no problems.
However, I am willing to deal with that because of how wonderful this product is! Once 1000P is applied, dirt, bugs, and bird bombs come off so incredibly easy compared with other products I've used - and I've tried lots! Hard water spots and stains are no longer the problem they used to be on my black car. It also leaves a very slick surface and beads beautifully. On black, it gives you a very nice glossy look, not all that deep but not as "plastic wrap" looking as many other sealants.
If the durability is as good as I've heard from others, this will be my go-to wax for a long long time!
Finish Kare FK1000P Hi-Temp Paste Wax is being ordered tomorrow. I'll always have a container in the shop so if you want it on your car next time your here just ask for it.
2006 dark blue Chrysler 300C Hemi is done.
ill be posting up the writeup sometime today.
hood
feb is half over, i hate this month!
---------- Post added at 06:38 PM ---------- Previous post was at 09:00 AM ----------
2006 dark blue chrysler 300C Hemi
look what i found in the trunk! i was pissed!
i called the customer & told him to throw this out in the garbage!
products used:
Meguiars Mirror Glaze 105 Ultra-Cut Compound (M105)
6.5" & 4.0" yellow pads
Meguiars Mirror Glaze 205 Ultra Finishing Polish (M205)
6.5" & 4.0" blue pads
3M Perfect-It Ultarfine Machine Polish (3M UFMP)
machine used:
Flex L 3403 mini rotary
protection:
Collinite 476S Super Double Coat Paste Wax
this was my first time trying out the Meguiars compound & polish. i was a stubborn mess & close minded when it came to trying out these new products. ive been using 3M compound & polish till i came across a tough black Audi S4 last week. the car was so bad the 3M compound just wasn't cutting the clear deep enough so i gave my friend phill a call & finally the Meguiars was ordered!
my only complaint with the Meguiars is the compound dries up hard like a rock. you shouldnt compound the car then leave it over night without cleaning up the splatter before going home! it seems to dust the same amount as the 3M compounds but it cuts deeeper & faster. if your good enough with the rotary wheel you can actually finish the M105 to a swirl free finish & then go straight to applying wax. the slower & longer i worked the product into the panel the better the reflection was in the clear coat. when i tried to pick up the pace of the compounding stage i was leaving light buffer trails & swirls behind. those trails & swirls are easily cleaned up with machine polishing but......working at a low rpm & with a slower pace made the polishing stage a lot easier. i didn't have any trails or swirls to remove with the polish. the polish kicked it up a notch & really glassed out the finish.
during compounding i never set the rotary any higher than 1000 rpms, i also polish at 1000 rpms.
it does take some time getting used to new products. after polishing half the hood, fender & drivers door with M205 i switched back to the 3M UFMP. i found the M205 a little difficult to work with. for me it seemed to create more dust than the 3M UFMP. i noticed when i would mist my pad with some water, it seemed to give the M205 a shorter work time before it dried up on the panel i was working on. 3M UFMP has a longer work time, creates less dust & makes less splatter.
shots taken of the passenger front door below the molding.
from about 3 feet away.
just like a fugly looking girl that looks good from far but far from good.
the closer you get to the car, the more your eyes bleed from the hacked up swirls & damaged clear coat.
every single inch of this car is covered with deep swirls that give the paint a dull, hazy reflection!
take a look at that dam door molding. yikes!
after compound & polish.
its hard to believe the clarity & reflection of the clear coat will be kicked up another notch.
i still need to wash off all the compound dust then blow dry it out, polish the entire car & apply a coat of wax to the surface.
a final inspection for each panel will be done under the bright halogen lights.
once all the swirls are removed, i can start to finish up the car & get it ready for delivery!
50/50 shots of the lower portion of the front passenger door.
left side is a before shot.
right side is after compound & polish.
left
right
right
heres another reminder of what that lower portion of the front passenger door looked like again before any compounding & polishing were done.
50/50 shots of the passenger side of the hood.
after compound & poilish.
heres a few blizzard rinse pics taken the other day. we just hosed the car down to get rid of the compound dust, we didn't soap it up,
the car was brought back inside for an ONR wipe down then dried with the leaf blower & an Absorber.
ill do some taping & prep the car for final polishing followed by a coat of
Collinite #476S Super Double Coat paste wax.
some final shots of the car just before the customer came to pick it up.
hood
roof
trunk
07 GTI done on tue 2/16/10
meguiars m205 ultra finishing polish
6.5" blue pad on Flex XC 3401 VRG Orbital
1Z Einszett Glanz Wax for the bottom coat
Collinite No.845 Liquid Insulator wax for the top coat
done on tueseday in the snow & ready to be shipped to croatia later on in the day.
2009 3 series with Collinite No. 845 Liquid Insulator Wax
PM or CALL for an appointment
(718) 445 9995
---------- Post added at 06:08 PM ---------- Previous post was at 06:30 AM ----------
g35x with collinite 476s super double coat detergent proof super double coat paste wax
hope everyone has a great weekend!
this is the last week of the Feb sale packages
PM or CALL the shop for an appointment
---------- Post added at 08:44 AM ---------- Previous post was at 05:26 AM ----------
White Audi A3 that underwent a full exterior clear coat correction last week.
removing the clear coat defects from the tightest areas of the car.
with M105
Hey Andrew I forgot that your shop is closed today, left you a message on your office phone.
I want to schedule two appointments for this month, Saturday 28th to be exact.
Vehicles that need your love and care:
1. Volvo XC90 (OPTION 4)
2. Infiniti FX35 (PAINT CORRECTION)
Please confirm.
Please confirm.
hey i just got your vm, i listened to it. im leaving in a few hours to spend the night in atlantic city with my gf & her family. ill be closed monday but back in the shop on tueseday. im just taking 1 day off. ill give you a call on tueseday to set up your appointments.
thanks,
andrew
Please confirm.
PM sent
Please confirm.
We have the same 2 vehicles, great minds think alike!
Hopefully I can get something done this summer. I know some people in the Minnesota MINI club (which is huge) and hopefully we can get some people interested in bringing you here.
it always comes down $ but im all for making the trip down there. its my goal this year to have my first out of state by plane mobile detailing trip.
if your the first to set something like this up for me ill take care of you with a lower price than the other cars on the list. that will be my little way of saying thank you for putting it all together. :tup:
How can I pass up an offer like that!
Status
