djpathfinder
- Edmonton, Canada
- 2005 FX45
Wheel spacers will bring your wheel/tires out so they won't look recessed in the wheel well. They are optional (mainly for looks). I could probably do with 15 mm spacers but I can get away with not using any as well. Depending on if you're going to lower it more (cutting 1/2 coil or part of the rear spring mount), you may have to be careful of the thickness of the spacer you use b/c your wheel could rub on the fender edge (metal).
Another instance where you may need wheel spacers is if you're looking at getting a big brake kit upgrade, so the calipers will clear the wheel spokes, depending on the wheel design.
