I played with it a little as well. Wanted to wire the power to the lower panel fuse box but couldn't find a cable to extend so didn't go through with it. So is this what happens when you just plug it in?
- The switch changes between input 1 and stock video?
- The reverse cam goes on whenever you put it in reverse, not depending on the switch?
So if that's the case, it's possible to input two separate video sources (say iphone and a dvd/computer?) without even worrying about the reverse cam..? Pretty excited about it.. Want to test out that video-out app on the iphone.. :.smile:
