stellanti
- Allston, MA
Thanks EG3! So it looks like I will go with the H&R DRS 20mm all the way around. I wont experience any issues with fitment with the 20" stock wheels, will I?
Thanks,
Steve
Thanks,
Steve
Thanks,
Steve
Thanks,
Steve
20mm spacers with stock 20's will be fine.
As Jeff said, there won't be any issues at all.. There's plenty of space both vertically and horizontally from the fenders before you experience any kind of rubbing.. You can't see from my picture but even with 20mm it's not completely flush with the top.
When you get the spacers installed (or install them yourself), make sure the centering ring is perfectly centered. Basically, if you can turn it with your hand easily or move it around even about 1mm, it will cause a slight vibration. You can get rid of it using teflon tape or electrical tape.. Just let us know if you experience that (hopefully not)..
Just to confirm...I have been on H&R 20mm spacers since the first month of owning my '07 and over a year on my prevoius '03.
Never experienced any problems...go for it!
Thanks for your advice! I am still on the fence about this one. I am concerned about the following:
1. Vibration at any speed
2. Tires kicking up road-grime all over side of car
3. With an H&R 20mm DRS style kit, will I need to modify the bolt length?
Please help me off the fence....
Thanks guys!
Thanks guys!
Verify the offset with a ruler and a straight edge. I have the H & R's and I'm also installing spacers, until i can find a set of wheels I can't live without. The front wheel sets in slightly deeper than the rear. It looks like perfect spacer combination with stock 20's is 25MM front and 20MM rear. check it out.
^^ Don't get the last type. Stock wheels won't fit over these unless they're >20mm
So are we all in agreement that the best and safest setup is either H&R 20mm DRS or ICHIBA 20mm V2? Both of them being through bolt set ups?
I'm worried about the weight of the vehicle sitting on just the aluminum spacer and press fit studs. Well, I wasn't, then someone had to mention it.
