ghettojiggalo
- burbank, ca
all the interior lights are the same size, 168/192 def. won't fit. you might still be able to use that 168 bulb for your blinkers/plates tho.
Hi,
Anyone here have LED or SMD front turn signals? Im trying to see if the signals will blink super fast due to the lower power consumption of these bulbs before picking up a set. If it does blink fast I might just stick with white xenon bulbs. Thanks for the help!
P.S. This is for the first gen 2006 FX35. Thanks
Yes, the LED turn signals will blink faster, according to other posts in this thread you will have to get a resistor to equal out the resistance.
I just purchased these and they are not working for DTRL (7440 style). I just pulled out the stock bulb and put these in... Any idea why it's not working? The stock bulbs still work just fine.
