2003 - 2008 FX Lighting Specs (Bulbs)
Discussion in 'FX (03-08) - Electronics & Lighting' started by Dr.2K, Sep 4, 2007.
  1. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    High and Low Beam Headights:
    -HID-D2S
    -Kelvin Rating = 4300k
    Parking Light / DTRL:
    -7443/7440
    Fog Lights:
    -03-05 = 9006
    -06+ = H8
    Reverse Light:
    -921/906
    Turnsignal:
    -7440/7443
    License Plate:
    -168/194
    Front Sidemarker:
    -194/168
    Rear Sidemarker:
    -194/168
    All Interior Ligthing:
    -DE3175/Festoon Dome Bulbs
    Below is a list of web sites that have these bulbs and corresponding LED bulbs for those that want brighter LED lighting. I am not affiliated with any of the retailers below in any way. I am just passing on information and my experience with these online stores which may help other members with their modding experience.
    http://www.autolumination.com/
    http://www.eautoworks.com/
    http://www.matrixracing.com/
    http://stores.ebay.com/MTEC-Automotive
    http://www.superbrightleds.com/
  2. brown_fv
    1,703
    Toronto, On
    Thanks for the guide, i just ordered a set of DTRL, Reverse & license plate LEDS
  3. Frankiago
    Frankiago Evo Troll Premium
    2,563
    IL
    Any personal experience on whiteness?
    The bulbs I first had as DTRL were pretty white, they matched headlights well, but had a very VERY slight hint of blue.
    The new ones are nowhere near white really... but they're "hyper white" or "super white" or whatever descriptive word they want to tie in.
    I'm wondering if anybody has had any experience with LEDs that truely were white light... I'm satisfied w/ my old LEDs for the interiors, they give a slightly blue hue, but the DTRL's I have aren't even close. Same w/ my reverses, and I'm afraid to put them in the side-markers cuz they'll look purple.
  4. Keemo
    Keemo Premium Member Premium
    1,108
    Edmonton,AB
    I've been meening to get an order going for DTRL's, fogs, reverse and license plates LEDs. Which ones did you go with?
    The 15 LED for DTRL's etc?
    ...OK after some searching here and the org, I figured it all out. Thanks.
  5. OP
    Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    I suggest using the white 36 led bulb from autoillumination for the 7440 or 7443 at 14.99 each.
  6. Keemo
    1,108
    Edmonton,AB
    Is this true about the turn signals? If I could I would replace the front ones with LEDs unless it did require that electronic flasher unit they discribe. Then I would just go with PIAA bulbs.
    http://superbrightleds.com/carbulb-notes.htm
  7. OP
    Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    Never tired them. But you can give it a try and post back your findings.
  8. rookie
    rookie Premium Member Premium
    2,201
    29
    Westminster OC
    Car:
    car
    LEDs in the blinker don't put enough load on the relay so it thinks it has already hit it and moves on so you get the fast flasher. The PIAAs are the easiest way to go, the orange is very slight and the bulbs have showed good life. Mine are still going. :)
  9. Psiclne
    Psiclne Guest
    one of my LED reverse went out - Gonna have to order a replacement - does anyone off hand remember how to replace it? Do I just remove the lil panel off the hatch door?? or is there tools involved? Im gonna put the stock bulbs back in in the meantime
  10. fxlr8
    fxlr8 Staff Administrator
    17,974
    772
    California
    Car:
    None
    If I recall you will pop off 3 little covers by each lamp and you will need a 10mm socket to remove the housing.
  11. Psiclne
    Psiclne Guest
    Cool - Thanks Jeff
  12. Keemo
    1,108
    Edmonton,AB
    For '07 you'll need a 8mm deep socket.
  13. Keemo
    1,108
    Edmonton,AB
    I installed the LED Reverse lights today and I have ordered a new set of 9 LED bulbs cause the ones I ordered were the Superstar from autoillumination. It looks cool at night, but the beam of light wasnt as wide as I wanted to fill up the reflector. And in the day it looks like a white dot. Here's a pic at night. I'll update when the new ones come.
  14. brown_fv
    1,703
    Toronto, On
    Looks pretty cool, i cant remember which #LED i ordered, but ill take a picture for comparion sake. how did you take a picture when your car was in reverse?
  15. Keemo
    1,108
    Edmonton,AB
    Cool, it'll be good to compare.
    I took it very quickly.;) JK, I just turned the key to acc. and put in in reverse without the engine on.
  16. Keemo
    1,108
    Edmonton,AB
    Here's the new LED. This one is the 9LED superwhite for reverse. And I ended up swaping out the PIAA LEDs for the lisence plate for some others from Autoillum. I just could'nt live with them being slightly different colors.
  17. brown_fv
    1,703
    Toronto, On
    what LED did you get for your license plate...i havent gotten LEDs for it yet and i hate my halogen look lol
  18. Keemo
    1,108
    Edmonton,AB
  19. asherchy
    asherchy Premium Member Premium
    1,676
    los angeles
    i have those
    they were a lil too blue at first but after a month they faded (right first then left a week later) to an almost lexus plate light color
    mine in about 5 months and going strong
  20. solekeeper
    solekeeper Member
    372
    South Fla.
    Very helpful!!
