- South Gate, CA
- 2003 FX45 AWD
FUGLY is right.. Mod are coming and the DTRL are on the TOP TOP TOP of the list....
Wow, Im on the edge of a thread being closed. Fellas I didn't see a post of how this was done. Can you direct me to where a DIY was done or anything? Thanks
Ton![]()
I believe jbaker has done this with a kp tech module
KP technologies fog light control installed! - InfinitiScene.com
part 1///1589
i was planning on doing it myself but i stopped when you had to do the wire wher eu needed an osciliscope or whatevr. so i brougth it in and they trashed the instrustions it came with and we used JOHNMAX's instructions that he posted on the .org. they were 567890 times better than the ones KP sent. they didnt even have pictures
anyways, probably took around an hour but i wasnt there to witness it cuza i was at school while my baby was at the shop.....so haha probably under an hour if you know the car and what your doing down there. my guy jsut doesnt know the fx really well. anyways. i thinhk its agreat mod and definately a must!!!!
link for JOHNMAX's tutorial:
http://infinitifx.org/phpBB2/viewtopic.php?t=17643&highlight=fog+light+controller
he's awesome
This write up covers installation of the KP Technologies Independent Fog Light Controller model# MX20. Their web site is http://www.kptechnologies.com
This module allows the fog lights to work reguardless of the headlight switch position, including when switching on high beams, as long as the fog switch is in the on position. If the switch is left on, they will shut off when the ignition is turned off, and come back on when the ignition is turned back on (as long as the fog switch is still on).
Professional installation is recommended. If you choose to do so please do it at your own risk. You will be wiring into sensitive circuits and modules.
The module comes with its own wire harness, and a relay and fuse holder for switching power to the fog lights. Here is a pic of the MX20 module.
The main module gets wired into the BCM which is in the drivers kick panel (left of the dead pedal). You will need to pull up the drivers sill plate trim panel by pulling up at the rear of the panel and continuing foward to remove it. Next you will have the kick panel cover to remove. There is a plastic nut towards the front you have to unscrew, then you can pry the panel towards the interior to release 2 clips that hold the panel on.
did you read the post? it links to the org with some great write up:
part 1
I chose not to do this mod myself.
mine are gonna look saweeeet
the guy whose doing them says he doesnt need the KP module, so we'll see what happens. i bet that he does....:frown:
anyways, looks great! i cant wait to do it!!!!!!!!!!!!!!!!!!!!!!!!!!!!![]()
Yeah.. not KP module is needed.... The only drawback is that the fogs are on 24/7
Pierce.. Maybe we can do it while we are at the track....
