infinitijosep
Hello,
I have a 2005 FX45 AWD with OEM navigator and I also have a Kirinavi HU sold by another seller and wubbalubbadubdub has helped me a lot by publishing the first pdf with the instructions since my Aliexpress seller did not give me any instructions or help me.
Indeed Luis, that connector labeled in Chinese as "low version", in principle has to be plugged into the connector that was plugged into the old screen for the low version, the FX35 / FX45 that do not have oem navigator. In fact it is the same as it was in the first PDF, but without having to solder the two green wires in the lower version. It is important that you keep the OEM AC module plugged in the new HU configuration.
You will explain to us how it goes.
Regards
Regards
