Making this shift mod redux post my home base for all that is, was & will be "onthemove". Hopefully some will find some of the info I post useful or @ least entertaining. Read many who claim the various aftermarket intakes are of little value. I beg to differ. I'll post some dyno results of the before & after of my custom 4" later. Will focus on intake temps which is a general aspect regardless of induction method, be it forced or N.A.. Was looking at gauges & what is actually needed to monitor & discovered scanguage 2 has some of what's useful & I can add to it which is a different topic. One function it monitors is the air intake temps via the MAF so I set it to that & selected a few others. I can see 4 functions at a time & it's directly plugged into the ecu port. Tonight it was a somewhat humid but still a comfortable 76*.
This was the temp. of the air entering my engine @ idle on after driving 15 minutes & idling for 5, bottom left w/the a/c on to get temps up & fan going. Top left is rpms & more accurate than the oem gauge per my tuner. OEM off 3-400 rpms. MPG's on the top right (far more accurate than oem) & timing bottom right. Many more options w/this thing. 0-60, 1/4 mile, 60-0 stopping times & more can all be recorded. It doesn't start timing until ecu reads motion (or braking for the 60-0 timer). I love this thing. Need to figure out how to program for trans & engine oil temps & oil pressure.
That's ridiculous. That's a double on the ambient & totally unacceptable. I noticed the other day how much hotter the I.A. was as compared to the ambient temps. So, I did some research & found two others, one w/a miata & the other a 350z, both with scangauge2's & both showing obscene I.A.'s. The MAF/ECU reads roughly 7-10* hotter than ambient for whatever reason & I know this because I can see the temps. as soon as I turn the key, cold engine. Not sure if there's a hiccup between the scangauge & ECU or what, but I've got a base & that's all that matters.
So, time for a prototype CAI conversion for the long 4" fatty pipe.
Made this in about 10 minutes. There's several points in the bay where it locks itself into place. No tape holding it to the bay. Drove it running some errands & temps were 15-20* lower, whether driving or idling yesterday. Same outside temps both days. It's a thicker than average gauge box so it does have some insulating properties to it which were obvious afterwards, though the difference could've been entirely from the "heat shield" effect, not blocking radiant heat but hot air. Radiant heat is really an issue with the aluminum pipe & is with plastic as well. Before the plasti-dip on the pipe, I couldn't touch it after driving & after the dip I can, so it helps but not enough.
The key is not just to get cooler air into the intake but also to convince the MAF that it's not seeing hotter air so it will stop pulling timing. I think resolving this issue will resolve the majority of heat-soak related power loss. An "air box" will be great for calming down the air @ the filter. The radiator fans definitely cause issues, just take a leaf blower & get close @ idle, not too mention hot air.
One thing to consider from the quotes below is that Mr. Motordyne is referencing testing on a dyno. For those who haven't been on a dyno yet, the hood is up w/a monster fan blowing 2' away from the radiator. When do you have such a situation on the road? Never, especially @ idle. I think the benefits are greater than what's written below...
An interesting take on the subject from a guy who ought to know;
Hydrazine
MOTORDYNE-MY350Z SPONSOR
" I've noticed while on the dyno the intake temps increased over time. I found it was due to heating of the MAF housing and the back side of the stock air box.
At idle, between dyno pulls, the radiant heat would increase air intake temperatures by ~20'F. 20'F is a lot! It would heat up the entire intake tract and
MAF sensor. And when I did the dyno pull, it would take several seconds for the MAF sensor to cool down... but by then it was too late.
The ECU adjusts spark timing based on air intake temperature. Consequently HP is directly affected by timing AND air temperature (IE air density).
And this was all because of heat soak between dyno pulls. It would cause dyno results to go down by 5-10 HP as the
air intake system became heat soaked.
For the purposes of R&D dyno testing of air intake and
exhaust modifications, the heat soak would throw off the accuracy of pre/post dyno testing, so I simply had to eliminate the heat soak.
I wraped the air intake and it helped stabilize temperatures and dyno results quite a bit.
It was exactly what I needed.
On the road, it won't make too much of a difference for continuous driving but it will help at the 1/4 mile track or any situation where you need to sit at idle for a length of time before launching."
And;
Hydrazine
Quote: Originally Posted by chamois
Thanks for the input. I found a website that said for every 11 deg. F the temp. drops you gain 1% in power. not huge gains maybe 2-4 hp but by using a $15 reflective tape or something from a hardware store it might help out a little bit. and the pic gothchic put up doesnt look to bad.
" Yes, 11 deg F = 1HP
And that only takes into account air density... If its air temperature as seen by the MAF, it makes even more of a difference."
