=ZebraFX= :: 2004 FX35 AWD
Work in Progress!
took me 4 days total. Didn't come out perfect(leaking brake fluid from the calipers messed up the paint in a couple spots, lesson learned:at-wits-end:).
The beginning
Sanded with a 600 grit
Painted black(for Akebono logos) with a Rustoleum High Temperature Paint
Akebono vinyl decals
Wet sanded with 1000 grit
Akebono decals applied
Painted with VHT SP402 Burnt Copper High Temperature Paint
Took off the decals and wet sanded with a 1000 grit again
Final stage, panted with Clear Coat High Temperature Paint
The results(thinking of redoing everything)
Wow... these came out real nice.
Question, does the wetsanding before the clear enhance the shine or the smoothness? Did you wetsand the clear also?
Wow. The burn orange look really sharp. Love the way they looks. :good:
---------- Post added at 01:48 PM ---------- Previous post was at 01:42 PM ----------
Mask it and do give those bad spots some light sanding and the a couple coats should do it :).
Yes it does, I think:). I'm planning to wet sand the clear and then polish it also.
---------- Post added at 02:56 PM ---------- Previous post was at 02:54 PM ----------
Thanks.
I'm still debating how bad are they, I put too many coats already, so I don't know what to do at this point. I will probably will leave everything as is.
---------- Post added at 02:57 PM ---------- Previous post was at 02:56 PM ----------
:congrats:
Thanks
