=ZebraFX= :: 2004 FX35 AWD
Work in Progress!
Will take pictures soon. The light output is the same, since there is no tinting involved(just inside housing painted black).
Couple more pictures outside
I used Dremel tool with 15/16" cut-off disc and glue gun(Ad tech Full size) from Walmart.
---------- Post added at 12:00 PM ---------- Previous post was at 11:43 AM ----------
During the process I have been taking pictures. Forgot to post.
Separated the lens with Dremel
Reflectors painted with VHT Nite Shades from inside
Glued everything back together
Painted from outside to cover the glue and cut off lines
Yes, was challenging first. Plastic is pretty flexible though. Forgot to mention, broke the lens when was opening the third tail light(was in hurry, so my fault).picked up a used one at local salvage yard(was lucky, paid only $60 for a used Sport Tail light).
How much to get your FX soundproofed?
---------- Post added at 12:47 AM ---------- Previous post was at 12:39 AM ----------
I should try the project with the spare red tail lights I have instead of my sports lights.
That just looks awesome man! Would you be up for making me a set?
Sent from my HTC_Amaze_4G
Already ran to some problems, tails were not completely sealed, some moisture inside(after car wash). Took them off and put some silicone. Will see...
Maybe you should have used some of that plastic weld stuff....
