I got my car back from the shop that put my motor in... when I got home, 3/5 lugs were FINGER TIGHT and the reason I popped the center cap off and checked was b/c there was some wobbly action goin on and some definite noise from the front end.
I told him about this and he was very shocked, said he torques 'em all to spec (he loves that term, and uses it on everything from bolts to grape jelly jar lids).
Disappointed, I changed out the graphite stock 20's with my 18" OZ's, made sure I tightened ALL LUGS.
Just yesterday I had some weird noise and felt some vibration, eventually turned into CRAZY noise and a small, pretty quiet knock.
First thing I did was get down to them lugs and try to unscrew them, they were on just fine and I couldn't turn them.
I then lifted up the front end (and unfortunately put some craters in the apartments' asphalt from my jack's wheels) and looked around. I saw some grease spatter and played around a bit and had some actual play on the driver's side.
I didn't check the lugs when it was lifted. So after looking around I took it in to the Muffler/Brake/Axle/etc. shop and they were gonna do a free diagnosis. I went n worked out, they called, I called back, they said the wheel was loose!
My roommate then reminded me that I checked the lugs when it was on the ground and if I were to check them lifted, they would've probably been finger tight.
The guy @ the shop said I'm using the wrong lugs on this thing...??? Ehhh... wtf?
I thought lugs were lugs when it came to the FX and I could use the same ones as 350Z's...
Not mentioning any names... but I got the lugs from a member here :err:
Soooo... WHAT LUGS DO I USE???
