buying some high flow cats which I can't used still sitting in my garage thought it was a good idea at the time but......
Should have went with 22s instead. I will swap them out when I find a good deal.
hid fogs. what a waste of time.
I regret replacing my stock rotors for drilled and slottedrotors. Now every time I have to stop short I can feel the brake pedal beingbumpy and also feel the grinding of the brakes.
I actually noticed a difference when I got my rotors swapped out for Stoptech drilled/slotted. Plus I did replace my braked pads with EBC Greenstuff pads which gave the brakes a bit of a bite. I also replaced the brake lines with stainless steel brake lines. Instill think the setup I have is better then the way it came with.I regret replacing my stock rotors for drilled and slottedrotors. Now every time I have to stop short I can feel the brake pedal beingbumpy and also feel the grinding of the brakes.
Regrets:
-Buying a bunch of bolt ons instead of saving up for FI.
among other things...
Subs, speakers, wheels, electronic gizmos, all of my performance mods, the exhaust fiasco, getting stuff painted, etc. it all adds up very quickly, you would be surprised.
+1. Definitely did not feel the slightest increase in performance either. I am thinking of getting the FX50 front brakes with regular rotors, but then i would have regular front and drilled/slotted rear...
To get back to this,
This is major reason I have not gone crazy with the new FX...its not worth it. I saw what happens when you do all of those little things here and they, most of which were pointless...this is why I try to share my experience with new members when the first thing they ask is "WHAT MODS SHOULD I DO" because I remember when I was there, and I didn't listenNow I try and do the same to new members by attempting to lead them in the right direction...:top:
