Where is it located MAP sensor?....
Jose Manuel
Valencia-España
Infiniti QX70
Jose
I have a 2016 Infiniti QX70 3.0d, and when I accelerate, it won't rev past 3,000 RPM, giving me a P012B error code, which means I have a problem with the MAP sensor (manifold absolute pressure sensor). I need to clean or replace it, but the problem is I don't know where it's located on the engine. I would appreciate it if someone could help me find it.
Thank you very much.
I've already managed to replace the MAP sensor, but it's still giving the same error code: P012b. I read on a Q50 forum that if the air filter isn't the original one (mine isn't), it causes this type of error. I don't know if it's the same for our QX70s. I'm mentioning it in case anyone else has experienced this.
Regards
